A Step-by-Step Guide to Making Your Own Christmas Wreaths and Garlands
Making your own Christmas wreaths and garlands is a fun, festive way to get into the holiday spirit! Not only will you save money, but you’ll also be able to customize your decorations to match your personal style. In this step-by-step guide, we’ll show you how to make both wreaths and garlands using materials that are easy to find. Let’s get started!
To make a Christmas wreath, you’ll need:
- a wire wreath frame
- a spool of green floral wire
- scissors
- a hot glue gun and glue sticks
- decorative elements like ribbon, berries, pinecones, etc.
First, take your wire wreath frame and wrap the green floral wire around it tightly, securing the end with a twist. Next, start adding your decorative elements to the frame using hot glue. Once you’re satisfied with the way it looks, cut off any excess ribbon or greenery and hang your beautiful new wreath on the door or wall!
To make a Christmas garland, you’ll need:
- scissors
First, cut a length of green floral wire that’s long enough to stretch across the area where you want to hang your garland. Then, start adding your decorative elements to the garland using hot glue. Once you’re satisfied with the way it looks, cut off any excess ribbon or greenery and Hang your garland on the mantel or staircase.
What’s more?
If you’re not into the DIY Christmas decorating scene, there are plenty of other ways to make beautiful wreaths and garlands. You can buy pre-made ones at most craft stores, or even order them online. But if you want something truly unique, try your hand at making one of these alternative Christmas wreaths:
A candy cane wreath
A candy cane wreath is perfect for kids (and kids at heart)! Simply hot glue candy canes onto a wire wreath frame, then add a ribbon or bow to finish it off. You could also make a gingerbread house wreath by gluing mini gingerbread houses onto a frame, or a popcorn and cranberry wreath by stringing popcorn and berries onto green thread.
A seashell wreath
This is a beautiful way to bring the beach inside your home! Simply hot glue shells of all shapes and sizes onto a wire wreath frame. You could also add a bit of greenery for a more Christmas-y look, or even some battery-operated fairy lights.
A wreath made out of old Christmas cards
A fun, festive way to recycle those holiday greetings you’ve been holding onto for years. Simply cut or tear the cards into small pieces, then hot glue them onto a wire wreath frame. You can also add other embellishments like ribbon, buttons, or sequins.
Another unique Christmas wreath idea is to make one out of corkboard! Cut corkboard into strips, then hot glue them onto a wire wreath frame. Once it’s covered, decorate it with Christmas-themed push pins, bows, or other small accessories.
Finally, if you want something that will last long after the holidays are over, try making a succulent wreath. Hot glue succulents and other drought-resistant plants onto a wire wreath frame, then hang it in a sunny spot. Water it occasionally, and your wreath will last for months.
You May Also Like
Eco-Friendly Christmas Celebrations with Unlit Artificial Christmas Trees
April 20, 2024
Making Your Christmas Tree Decorating Experience Better with Exercise and a Healthy Mindset
January 8, 2024
